Posted by redforlife on April 14, 2014 at 13:19:52 from (68.234.121.124):
In Reply to: 300 runs wont run posted by greg potts on April 14, 2014 at 11:16:48:
If you have good fuel flow, did you check it at the line going into the carb? Its sounds like you might be haveing trouble with fuel flow at the float/needle valve inside the carb. Could be dirt, but needle valve sticking closed is a better guess.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
