If your 6 Volt battery in your H is bad, and you've got a good 8 Volt battery sitting around, it sure is a lot cheaper to install the 8 Volt battery and live with the (minor) limitations.
Normally the 8 Volt battery is considered to be like putting a bandaid on a sucking chest wound.
Functionally, it will not cause any damage to your electrical system.
The problem will be in charging it. If your generator isn't charging the 6V battery, it sure as heck won't charge the 8V. It'll start good a couple times but you'll be right back in the same boat after that.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
