Re: Oil Film on M Breather Cap
Posted by Bob M on February 18, 2014 at 07:19:01 from (74.67.191.209):
In Reply to: Oil Film on M Breather Cap posted by wicksfield on February 18, 2014 at 06:20:19:
Sounds like crankcase blowby going out the vent tube into the air cleaner inlet pipe.
Check that the large breather tube (it runs from the tappet cover down to behind the left frame rail) is not plugged, kinked or otherwise restricted.
If the breather tube is clear the problem is excessive blowby - time for a ring job or engine rebuild.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
