Oil vapor condenses on any surface cooler than its liquid temp. (almost anything it touches cooler than 350 degrees) Thus normal oil vapor deposition (never visible or an issue on pollution controlled cars from about 1973 due to adopted positive crankcase ventilation regulations)is to be considered normal. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
