Posted by rustred on February 15, 2014 at 08:17:41 from (74.214.152.80):
In Reply to: info on farmall tractor posted by Richard Homer on February 15, 2014 at 07:02:06:
one of two things, it could be the bull gears frozen from water. use a tiger torch and heat up housing. it also could be brakes seized up , but unlikely as it will be band type brake bands. the disc's on the super model's do seize and require the drum to come off. sometimes a rap with a ball peen hammer does the trick after loosening the bolts also.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
