1086 IH cuts off
Posted by Russell Moore on February 14, 2014 at 21:21:24 from (74.243.158.186):
My 1086 cuts off if I pull it down below half throttle
I had a guy tell me the injection pump may be bad in it
anyone have any other ideas
also to crank it the throttle has to be full open with some either
I just bought the tractor
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
