Posted by D Slater on February 07, 2014 at 17:24:14 from (184.14.204.229):
In Reply to: 1950 farmall m posted by scott-in-mich on February 07, 2014 at 16:00:40:
Standard electric equipment for a 50 M was a relay or cut out to serial number 229910. 229911 and higher which was built in may was a voltage regulator. If nothing was changed the voltage regulator mounted on the rear fuel tank support and the cutout on the generator. If I remember correct the ones with a regulator have a fuse holder button in the gage box cover and the cut out doesn't have a fuse accessed from the outside of the box.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
