Re: Farmall H Adjustable Wheel base
Posted by athol carr on February 04, 2014 at 14:32:33 from (115.188.3.223):
In Reply to: Farmall H Adjustable Wheel base posted by redblood on February 03, 2014 at 13:29:24:
The adjustable wheel base was so that you could use the extended wheel base setup if you wanted the row crop cultivators mounted, the axle was far enough forward to clear the standard Farmall M cultivators. The rear (shorter) wheel base setting gave about the same wheel base as the narrow front Farmall M so more maneuverable but the axles would interfere with trying to mount forward cultivators.
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
