Posted by GordoSD on February 02, 2014 at 07:14:49 from (216.106.251.211):
In Reply to: 53 Super H Stalling posted by chemrhetoric on February 02, 2014 at 07:07:26:
For quick inspection just drop the bottom of the carb. That will allow you to check the float bowl pin, the needle and seat and the float adjustment. Make just a tad of an increase in the height of the fuel level.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
