Posted by Owen Aaland on January 21, 2014 at 15:14:11 from (216.47.34.47):
In Reply to: mcv posted by gbs on January 21, 2014 at 14:46:52:
Since you still have a MCV for the TA there was some provision made to block off the holes for three tubes that lube and control the TA. Depending on how those hose were blocked off it may require a different center section housing or some creative machining. I have seen the holes welded shut and have seen them drilled, tapped, and plugs threaded in.
The orifice has a screwdriver slot on the end. You may be able to modify a screwdriver to remove it but they can be installed quite tight. I have an Allen Hex wrench modified to do the job.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
