Posted by ih_bug on January 07, 2014 at 00:36:32 from (66.103.46.62):
In Reply to: Re: Magnetic Heaters posted by ih_bug on January 06, 2014 at 12:10:40:
thought maybe I should clarify . The 2 places I have used one. one is a 7 gallon steel hydraulic tank outside . the heater works really good but takes 10 hrs. will throw a blanket over the tank next time good idea. the other is a cast iron oil pan with 10-12 liters of oil in it outside again. minus 20 and 30 Celsius.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
