Red hot muffler with fire comming out has always been considered normal under a constant heavy load, all makes, you do not realize it if you are only working in daytime but see it when out after dark. Not unusuall to see the fire 6" above top of muffler. Also when it gets dark you can a lot of time shift up a gear due to night air giving more power.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
