Posted by pete 23 on December 23, 2013 at 10:55:25 from (74.33.91.156):
In Reply to: 1086 motor posted by MNHighwired on December 23, 2013 at 00:45:37:
There was no difference in cavitation between a 414 and a 436. Same sleeve, same bore size, different stroke. The reason for using the 436 in the 986 was to improve fuel economy of a non turboed engine. It also used a different injection nozzle for that same reason. Don't worry, I asked plenty of questions about that when they introduced that line of tractors. Us guys in the shop had to field a lot of questions from customers.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
