Re: 1086 motor
Posted by Aces on December 23, 2013 at 07:54:29 from (64.5.67.237):
In Reply to: 1086 motor posted by MNHighwired on December 23, 2013 at 00:45:37:
IH put the 436cid in the 986 because they had problems with the sleeves in the 414cid with out a turbo and did not want the 986 same as 1086.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
