Re: Farmall Super C Engine Sputters (I tried searching)
Posted by soundguy on December 14, 2013 at 17:02:04 from (207.30.46.70):
In Reply to: Re: Farmall Super C Engine Sputters (I tried searching) posted by dadgummit on December 14, 2013 at 16:49:27:
might simply free up with some lube if the are stuck.. but check arms.. etc. never know what you will find.
if advance is good, enrichen her a bit and recheck.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
