Posted by PUTTER on December 13, 2013 at 18:33:02 from (184.158.58.239):
In Reply to: Re: Changing hyd oil posted by Al L. in Wisc. on December 13, 2013 at 08:31:42:
I disconnected the coil wire and spun her over Al and that got some out of the pump. I tried blowing the lines out with compressed air but didn't have much luck with that. I unhooked the lines to the fast hitch cylinder and lifted it with my shop crane and that worked to force the oil out of there. My Grandson and I unhooked those lift cylinders on the loader and I was expecting the oil to come out of the other fitting, got a bath. Yes I finally got the loader on and running, it has the manure bucket with the snow extensions and was modified by the PO. I think I will get good at taking it off because I don't like all the extra weight up front, steers hard even with power steering. Plan on building a more conventional bucket for it. I have changed the hyd oil before but never went through all the draining of the lines and cylinders, hope it makes a big difference. I hope to clean her up and paint her if I ever get a period of time that i'm not using it. Merry Christmas Lyle
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
