Re: Farmall 460D Hydraulics Problem - SLOW
Posted by John Athey on December 01, 2013 at 14:30:44 from (173.10.129.193):
In Reply to: Farmall 460D Hydraulics Problem - SLOW posted by John Athey on November 30, 2013 at 14:45:49:
Just wanted to say thanks for the advice. A new filter, 10 gallons of new fluid and cleaning the screen solved the problem. Works good again.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
