Posted by RustyFarmall on November 16, 2013 at 12:35:41 from (208.126.186.41):
In Reply to: hydraulic hose leaks posted by BigTone on November 16, 2013 at 12:00:01:
Pipe style fittings need to be as tight as you can get them. If it ain"t tight, it will leak. Another thing to consider is where your various fittings came from. Most of that stuff comes from China. There really is no choice, so you may want to try some different fittings. Some are good, some are not. You never know until you put it to the test.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
