Posted by Janicholson on October 16, 2013 at 05:30:37 from (199.17.6.25):
In Reply to: H Tachometer ?? posted by FBH44 on October 15, 2013 at 23:50:28:
The third wire is probably the illumination. It could also be the power input to the tach. Look at the cluster and see if there is a general lighting system, or independent bulbs. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
