Cut them out of steel cans. Various thickness shims are pretty easy to make. Use a micrometer and measure the existing shims to predict the thickness of the thin ones. Do not use aluminum or galvanized tin. Shimming is done to preload bearings and is not made un reliable with nice round home made shims if none can be found. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
