Posted by The tractor vet on September 27, 2013 at 20:54:54 from (75.19.125.100):
In Reply to: brakes on 806 posted by mr cat on September 27, 2013 at 17:29:44:
My guess is that you have and adjuster problem or you really do not have it put together correctly . With the engine running you WILL have a slight amount of fluid seepage when you open the bleeder and this will not cause a problem . In all my years working on Farmalls i have never had to but once get into a brake valve and that was because of the headed pin froze up and the man broke the end off the valve . IF one of the adjuster is not working correctly and the brake disc's get cockeyed and the brake piston is setting cockeyed then you will have brake drag and heating . Did you replace the little adjuster clippies with new ones and did you reset them and see if they will only screw out and not screw back in ?? , best check that as this is where i think your problem lies .
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
