Posted by jiminy on September 26, 2013 at 04:47:17 from (216.227.61.96):
In Reply to: ihc 3688 hydrualics posted by Andy Kitching on September 24, 2013 at 18:56:27:
I have one of these and have experienced about every problem one can have with it..first the hitch pump is located down behind the rear tire on the clutch side..valves are on the oppisite side. the o ring mentioned sounds as if it could be your problem if things went away gradually. it is located in the pump mounting plate to remove you must drain all hyd oil and remove plate..pump will come with it..pump can be inspected when you do this..when the pump shaft breaks its usually still on pump but you can turn it easily..if its good it should be difficult to turn. post back and let us know what you find.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
