Posted by JimB2 on September 24, 2013 at 17:56:59 from (99.241.76.141):
In Reply to: Instruments on IH-784 posted by jp2code on September 24, 2013 at 10:26:26:
Hi, Wiring diagram can be found at: http://cngco.com/wiring_diagrams/IH%2054-74-84%20SERIES.pdf
Re fuel gauge, I believe that the fuel gaug showing full is that there is a short to ground in the wiring harness. The wiring harness goes from under the dash on top of the transmission under the sheet metal cover, under the seat to a molex connector behind the seat and then to rear lights and fuel tank. There is one ground wire that is connected to a bolt at behind the seat on deck plate. Re hour meter, does the Tachometer work? If no then drive cable or drive gear on front of engine. If yes then have to send hour/tach for repair. Re temp gauge, could be coolant sensor that is located in coolant manifold by the thermostat. Could also be a wiring issue.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
