Re: coil getting to hot!!!
Posted by dick on December 02, 2000 at 08:12:16 from (199.239.12.58):
In Reply to: coil getting to hot!!! posted by ranparr on December 02, 2000 at 03:56:37:
Couple of things you might check/try: First, check the voltage between the resistor and your coil to see if the resistor is doing the job. You can do this both with the tractor running and stopped. When stopped, you should see the full battery voltage between the coil and resistor when the points are open, and about half when the points are closed. If you see half the voltage with the points open, you've probably got a bad condenser, although a short somewhere in the distributor is also possible. When the tractor is running, you should see a fluctuating voltage alternating around maybe 8 volts between the coil and resistor. Since half the voltage drop is supposed to take place across the resistor, it should be as hot as the coil, or something is probably wrong with it. If you're more into the plug-in-new-parts-until-it-works school, try a new condenser or two - these things don't seem to be as reliable as they once were, and not many people claim to know how to check them, so trying more than one isn't a bad idea. They do have the advantage of being relatively cheap. Hope this helps, and good luck. My bet is you've got a bad condenser from your description.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
