Posted by JimB2 on September 15, 2013 at 15:12:59 from (99.241.76.141):
In Reply to: 354 3pt leaking down posted by steven in tn on September 13, 2013 at 18:49:41:
Hi Steven, I have never had the opportunity to replace seals on the 3pt cylinder. We had a 434 with the leak down problem but it was our loader tractor and we didn't use the 3pt that much. I don't know if you have to remove the hydraulic housing or if it can be removed by removing the front off the hydraulic housing. Consult an IH repair manual.
Link to caseih parts diagram: http://partstore.caseih.com/us/parts-search.html#epc::mr52549ar964278
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
