Check to see that all the cam lobes are the same height. Check the width of each cam at the shaft. The height minus the base circle is the lift. See how what you've got compares to the specs.
Keep the lifters in order in case you do not need to have the cam reground. If you have the cam reground, resurface the lifters. You might consider having the cam ground to Super M specs.
Like everyone else says, flatten out the lifter faces. Push rods should be straight. I like to keep them in order too.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
