Sounds like you have hooked your test gauge and valve right into the line from pump to steering valve, and also sounds like the flow has to go through your valve and cannot get around it. If so, then you have indeed confirmed you have very little flow and pressure so your pump would indeed be bad. Realize though that the pump contains the combination pressure relief and flow divider valve so that could be stuck or broke. Might be worth checking that out when you pull pump out. Should have 1200 psi and 3.5 gal flow per minute at about 75 percent of that max pressure.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
