Posted by Blackriver on August 27, 2013 at 18:03:50 from (173.202.78.213):
I have started work on my Grandfather's Farmall B, and can't locate the engine crank. I'm just trying to see if the engine is free or seized. There is a hand crank on an old Famall H, does anyone know if the crank from the H will work on the B?
This post was edited by Blackriver at 18:14:57 08/27/13.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
