If that"s a B series pump (no scavenging valve and pump)then the drain tube in the bottom is probably plugged with dirt and the leakage fuel from the valves is building up in there and overflowing. Run a piece of wire up through the drain tube and you will probably get dirt and a rush of diesel fuel out of it. The pump can then drip out the leakage fuel and it won"t be finding its way out the throttle shaft.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
