Posted by FBH44 on August 15, 2013 at 19:55:59 from (64.85.215.92):
In Reply to: year of my farmall H posted by August Smarra on August 15, 2013 at 14:55:12:
Yep, that's it, 1947. Here's the rest of it; FBH means a Farmall 'H'. Q is the code casting letter for 1947, and you'll probably see all sorts of Q dates on various cast parts, for example 3.12.Q, meaning March 12, 1947, the date that particular part was cast at the foundry. The system started in 1931, with 'A'. X1 means gasoline engine.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
