There is another option, which I used successfully. Simply heat the flywheel on your bbq grill to 300F or so, don your welding gloves, and it will slide on with minimal effor. I froze the pin for a couple hours also. Takes 2 people to slide it on since the flwheel weighs so much. Install the pin before everything cools. Works like a champ. It was a 1 minute job after the flwheel was hot. You might want to stage the process first so you can get a feel it. Learned it from a old crusty F-20 guy and it was crazy how easy it was. You can spend the time to make the tool, or you can light the grill, install the flywheel and have a brat afterwards with your buddies.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
