Posted by Janicholson on June 21, 2013 at 13:04:29 from (74.60.94.18):
In Reply to: Re: IH 2424 posted by TGIN on June 16, 2013 at 08:20:53:
Roller bearings and some ball bearings will lock up when failing. Pull the drain plug and see if there is metal in the first oil that comes out. My bet is a bearing. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
