There are bushings in the pump (no real noise there when flooded with oil) but if worn enough to allow the gears to rub the housing, certainly that wear will cause noise. If you are running hytran or other thinish tractor Hydraulic oil, try a 15-40, or straight 40 in the entire system to see if it will improve. This only works if the tractor and disk are not shared with other equipment or tractors that require Hytran. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
