Posted by rustcollector on May 30, 2013 at 16:49:08 from (70.196.1.122):
In Reply to: Power Unit starter posted by Yooper Farmall on May 30, 2013 at 16:12:33:
Yes, the starter will turn opposite direction than a tractor starter. Engine turns in the same direction as tractor. These starters may be hard to find.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
