Posted by gleanerguy on May 16, 2013 at 07:51:35 from (199.150.177.66):
Recently my 684 has stopped charging (I get only 12.25 volts while running). Last year I had the alternator rebuilt by a good shop nearby. I took it back to them and had it tested and they said it is good. So I have a wiring problem.
I dread having to tear apart the wiring to figure this one out. I think it takes a 205 ohm resistor in there somewhere to get it running? As you know they use a Lucas alternator. I would prefer to just put a Delco-Remy one wire alternator in, but they are quite a bit larger in diameter and will not fit. The Lucas alternator just fits, I can just barely slip the belt off with it loosened up all the way. It would have to be something of the same or slightly smaller diameter to work.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
