Posted by John T on May 02, 2013 at 11:57:05 from (216.249.82.117):
In Reply to: Hotter spark plug posted by Bob Reineke on May 02, 2013 at 10:46:45:
Best I recall the Autolite 3116 is in the vicinity of the heat range around a 386 or hotter 388 Autolite. However its a non resistor plug I believe which Id especially recommend if you had a Magneto Ignition.
Other things which can help if fouling is a problem for which youre seeking a hotter plug is to use hotter thermostats (if a T stat tractor) or radiator air deflectors or shutters etc TO RAISE THE OPERATING TEMPERATURE,,,Dont run the carb richer then necessary,,,,,,,,Use wire core plug wires, keep the ignition well tuned.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
