Posted by FBH44 on May 02, 2013 at 00:20:34 from (64.85.214.231):
In Reply to: Carb kit posted by Harrison58 on May 01, 2013 at 21:07:20:
Here"s previous advice how to adjust things;
Make sure the float isn"t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so it doesn"t rub or touch. Pretty important. Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber. Initial settings as follows to get it started; Main fuel adjusting screw, big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture. Idle fuel-mixture screw, smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner. Idle speed screw, faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages the slot. Get the engine warmed up, and idling. Turn OUT the idle fuel-mixture screw until rough running, then turn in until it idles smooth. (Mine is set at 1 turn open.) Rev it up, wide open, warmed up, then turn the main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. As I say, mine sits at 1 turn open. (Other advice has been to set it at 2 1/2 turns open for pulling implements.) Should rev up smoothly and evenly. Too Lean = stumble, sputter, damaged melted plugs. Correct = tan plugs. Too Rich = back smoke, black sooty plugs.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
