Posted by Mark Robke on April 20, 2013 at 10:54:01 from (71.31.23.1):
In Reply to: Re: Too much? posted by Dave H (MI) on April 18, 2013 at 07:24:26:
If I was using other implements, I would take the loader off. You said you were using the origional mccormick loader which is a u-34. It only takes 5 minutes to remove and 10 to install. It sounds like you have the correct valves for the loader; there should be 3 hose connects on r/s and 1 on l/s. I just made hoses to run from the outlets/connections to the rear of tractor to hook to my implements. The u-34 in my opinion, was one of the first quick attatch loaders. Mark
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
