Re: Too much?
Posted by mkirsch on April 19, 2013 at 07:03:55 from (64.80.110.74):
In Reply to: Too much? posted by Dave H (MI) on April 18, 2013 at 06:50:34:
The key to adding separate remotes for the loader is to either:
1. Redirect the oil going IN to the factory valve stack to the loader's controls, then back to the valve stack.
OR
2. Redirect the oil coming OUT of the factory valve stack to the loader's controls, then back into the tractor's reservoir.
I know it's possible on a 300U, but I don't know how it's done.
The pump should be 12GPM and 1250PSI. That's adequate for a loader
Does the tractor have good tight powerful power steering?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
