Re: Too much?
Posted by rustyfarmall on April 18, 2013 at 07:36:34 from (216.248.71.226):
In Reply to: Too much? posted by Dave H (MI) on April 18, 2013 at 07:24:26:
It does get to be a bit complicated doesn't it? Having said that, I'll also say that nothing is impossible if you want it bad enough.
Does the tractor have fenders? Maybe you could mount the loader controls on the fender?
Might need to "TEE" into the main hydraulic supply BEFORE it goes into the existing remotes?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
