Posted by Bob M on April 06, 2013 at 12:55:44 from (67.240.171.136):
In Reply to: Stumped posted by Dan Richardson on April 06, 2013 at 10:18:30:
Dan - If running at partial choke stops the loping, problem is a chronic lean condition. A few common causes:
- leak at the carb to manifold flange - leak at the manifold to head gasket - a plugged carburetor port - especially the idle port in the carb throat by just above the throttle plate - float level set too low - broken idle mixture screw (note turning the screw IN makes the mixture richer) - improperly assembled carburetor
Also do as Bouncer suggests: Check for good fuel flow into the carburetor. Remove the drain plug or cock from the bottom of the bowl - it should flow a solid stream of gas. If gas just dribbles out there's a restriction)
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
