Posted by ss55 on March 26, 2013 at 21:59:14 from (173.31.19.80):
In Reply to: Oil Change???? posted by WI-Ed on March 26, 2013 at 17:36:34:
If your temperatures are above freezing and if you are concerned about condensation or coolant in the oil, you could crack open the drain plug enough to let any water drip out and re-tighten the drain plug when oil starts to come out. After that I'd wait to change the oil until the first time you run it enough to get the engine up to full operating temperature.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
