Posted by rustred on March 26, 2013 at 21:07:58 from (24.114.27.195):
In Reply to: Oil Change???? posted by WI-Ed on March 26, 2013 at 17:36:34:
the only time i drain without starting is on one that i bought that has been sitting for years. i then get it running then warmed up and do the oil and filter thing. otherwise the sediments are just sitting on bottom of pan. lots of times you can stick your pinky in the drain hole and feel the sludge. myself i would start them first.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
