Posted by farmallhal on March 26, 2013 at 19:46:26 from (76.0.41.160):
In Reply to: rust in fuel tank posted by whigg on March 26, 2013 at 17:50:36:
I took one to a radiator shop that did a great job removing the rust and crud and installing the liner. I found that to buy all the required chemicals, cleaner and sealing products needed to do the job correctly the cost was very close to what I paid the radiator shop. As I recall the cleaning and the coating was $120 and has been trouble free since then, Hal.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
