Posted by Old weldor on March 26, 2013 at 18:50:07 from (67.142.183.20):
In Reply to: rust in fuel tank posted by whigg on March 26, 2013 at 17:50:36:
If you don't get it clean enough and you pour tank liner in it you will have problems later on. If it is only slightly rusty you might get it clean enough with muratic acid, if it's really bad,I would take it to a radiator shop that has an acid tank,and have them clean it. Then put liner in.i I have done several for classic cars and tractors with no problems.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
