Nominal block bore without sleeves. H block 3.562. 350 tractor block. 3.750. Original piston pin diameter H- 1.109. 350-.875. IH sold pistons for all with .875 pins and used adapter pin bushings in the rod. Aftermarket mostly sells big pins for H and SH and small for 300 and 350 piston and sleeve sets. Always a chance for a pin hole in the cylinder wall when boring the H block to 350 size. But H blocks are cheep. Counter bore in block needs changed also if using off the shelf sleeves. Would look for a 300 or 350 block. May not cost any more than the machine work on a H block.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
