Re: Found on the Side of the Road
Posted by Old-F20 on March 22, 2013 at 11:53:11 from (71.7.101.5):
In Reply to: Found on the Side of the Road posted by SadFarmall on March 21, 2013 at 00:54:37:
Hey Sad, one mor ething i will add. if the serial number is over TG99926 then its a '22-36' even though the serial tag says 15-30 tractor on it
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
