Posted by pete 23 on February 28, 2013 at 17:39:35 from (74.47.40.242):
In Reply to: 400 diesel missing posted by Brad clemmons on February 28, 2013 at 11:21:35:
The decompression valves are open when on gas. They close when switched to diesel. So, if you pull the spark plugs out, put decompression lever in diesel position,ground coil wire or unhook primary wire to coil so you don't stat a fire, hit the starter and no compression should come out of the spark plug holes. If it does, decompression valves are stuck or warped. You can get get at the top end of them valves with valve cover off. May be able to see a stuck valve through spark plug hole. Difficult though. If they are not stuck too bad you can go through hole and push them up. Then pull lever back to gas to open them, then again to diesel. Doing that several times may loosen them. Probably not though.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
