Posted by Farmerhr on February 10, 2013 at 19:37:07 from (108.224.0.124):
Does anyone know how IHC put the king pin into the wheel spindle ? When I look at the joint, I can see where the wheel spindle has be machined for the king pin and there is a center in the end of the king pin. There are no welds that I can see. I realize that the assembly was not made to be serviced. However; my wheel spindle is fine but the king pin has been welded on, ground, and mutilated and I would like to try and replace it. There are replacement assemblies available but I would like to explore rebuilding what I have. Thank You for any help you may be able to offer.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
