Posted by MRF-Engines on February 09, 2013 at 03:11:26 from (67.141.1.183):
In Reply to: Brakes on Super A posted by nh8260 on February 08, 2013 at 21:07:22:
It"s not too bad of a job. you have to remove the drop housings to get to them. The right side is between the drop housing and the axle housing, and the left is between the tranny and the drop housing. I usually remove the tire and center, then take the bolts out and slide the housing and axle out of the tranny. Just be carefull of the seals and actually is a good time to look at them and replace as needed. The housing is heavy, if you have a lift or a friend available see of you can have them help. Check the new brake bands over good too, I had a new one come apart in the middle of winter while i was plowing on my Super A. Fourtunatly it didn"t bind up but I had to pull it all back apart to fix it. Good luck.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
